Connect04337.pngRenumbering devices and sockets
Command
Path
Renumber Devices or Sockets
ConnectCAD > Drawing
Renumbering devices and sockets is useful when designing a new system with numbering that depends on the device and socket names. For existing systems, use caution when renumbering, since the cable numbers should match the cable numbers that have already been installed on site.
To renumber selected devices or sockets in the drawing:
Select the devices or sockets to renumber. You cannot select a mixture of both.
Selected devices are renumbered in the order in which they were drawn.
Select the command.
The Labeling Options dialog box opens. Select either numeric or alphabetical labeling.
Parameter
Description
Numeric
Start
Select the starting number; if the desired number is not in the list, select Custom to specify a custom start number in the Add New Start Number dialog box
Increment by
Select the increment interval
Format
Select the number of leading zeros
Delimiter
Select a delimiter character to place before the number
Alpha
Start
Select the starting letter
Increment by
Case
Choose either upper or lower case letters
Delimiter
Select a delimiter character to place before the letter
Numbering Direction
Select the numbering direction. The stacking order of the objects is usually the order in which they were added to the drawing.
Example
Displays a preview of the selected labeling options
Numbering circuits
Placing devices
Adding sockets, loops, and terminators
ConnectCAD
